Ir para o conteúdo principal
Kirby G5 Vacuum Belt Replacement
O que você precisa
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: passo 1, imagem 1 %32
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: passo 2, imagem 1 %32 Kirby G5 Vacuum Belt Replacement: passo 2, imagem 2 %32
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: passo 3, imagem 1 %32
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: passo 4, imagem 1 %32 Kirby G5 Vacuum Belt Replacement: passo 4, imagem 2 %32
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: passo 5, imagem 1 %32
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: passo 6, imagem 1 %32 Kirby G5 Vacuum Belt Replacement: passo 6, imagem 2 %32
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Conclusão
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
Uma outra pessoa concluiu este guia.
Gina Trojano
Membro desde: 04/22/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 58
Duração total: 1,118
