Ir para o conteúdo principal
Kingston HyperX CloudX Speaker Sponge Replacement
O que você precisa
  1. Kingston HyperX CloudX Speaker Sponge Replacement, Speaker Sponge: passo 1, imagem 1 %32
    • Remove the ear cushion from the earphone.
  2. Kingston HyperX CloudX Speaker Sponge Replacement: passo 2, imagem 1 %32 Kingston HyperX CloudX Speaker Sponge Replacement: passo 2, imagem 2 %32
    • Remove four 11.2 mm screws from the earpiece using a Phillips #00 screwdriver.
  3. Kingston HyperX CloudX Speaker Sponge Replacement: passo 3, imagem 1 %32 Kingston HyperX CloudX Speaker Sponge Replacement: passo 3, imagem 2 %32
    • Use a spudger to pry the top plate away from the motherboard.
    • There will be a groove in between the two plates to insert the spudger.
  4. Kingston HyperX CloudX Speaker Sponge Replacement: passo 4, imagem 1 %32
    • Use the metal spudger tool to scrape off the old foam pad and any remaining glue.
    • The plate does not have to be completely clean after removal, just clean enough to securely attach the new sponge.
  5. Kingston HyperX CloudX Speaker Sponge Replacement: passo 5, imagem 1 %32
    • Line the edge of the headphone plate where the original pad was with superglue.
    • Press the new sponge into the glue and allow it to dry fully.
    • The new sponge may need to be cut to size in order to fit on the headphone plate.
    • Make sure the glue is completely dry before reassembling your device. Failure to do this may result in damage of your device.
Conclusão
Kosie
Membro desde: 03/01/23
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 90
