Ir para o conteúdo principal
Kingston HyperX CloudX Ear Pads Replacement
O que você precisa
  1. Kingston HyperX CloudX Ear Pads Replacement, Ear Pads: passo 1, imagem 1 %32
    • Place one finger on the inside of the cushion and place the other finger on the outer rim of the ear pad cushion.
    • Gently pull the ear pad away from the headset, removing the flap from the groove until the old ear pads are fully detached.
  2. Kingston HyperX CloudX Ear Pads Replacement: passo 2, imagem 1 %32
    • Take the new ear pad and slide the top side of the flap into the groove of the ear cup.
    • Once the flap is inside the groove, slide it all the way in to make sure the flap is secured inside the groove.
  3. Kingston HyperX CloudX Ear Pads Replacement: passo 3, imagem 1 %32
    • Squeeze the top part of the cushion into the earcup to keep it secure and prevent the flap from sliding out of the groove.
    • Make sure to keep a tight squeeze onto the cushion until it is fully secured onto the earcup to prevent the flap from slipping out.
  4. Kingston HyperX CloudX Ear Pads Replacement: passo 4, imagem 1 %32
    • Slowly start going around the outside of the earcup and stretching the cushion so that the flap is secured into the groove.
  5. Kingston HyperX CloudX Ear Pads Replacement: passo 5, imagem 1 %32 Kingston HyperX CloudX Ear Pads Replacement: passo 5, imagem 2 %32
    • Push the flap further into the groove by taking a spudger and going around the outside of the headset slowly pushing the spudger into the groove to make sure the flap is fully secured into the groove.
    • If you do not have a spudger, you can also use a credit card instead.
  6. Kingston HyperX CloudX Ear Pads Replacement: passo 6, imagem 1 %32
    • Squeeze the ear cushion and move it slightly back and forth to ensure the flap is secured.
    • Repeat on the other side.
Linha de Chegada
Sam Bloch
Membro desde: 03/01/23
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 469
