Ir para o conteúdo principal
Kingston HyperX Cloud II Speaker Wire Repair
O que você precisa
  1. Kingston HyperX Cloud II Speaker Wire Repair, Kingston HyperX Cloud II Speaker Wire Repair: passo 1, imagem 1 %32
    • Pulling along the edges, take off the ear padding.
  2. Kingston HyperX Cloud II Speaker Wire Repair: passo 2, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Speaker Wire Repair: passo 3, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 3, imagem 2 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 3, imagem 3 %32
    • Remove the inside bracket support, and then remove the outside bracket support.
    • Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Speaker Wire Repair: passo 4, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 4, imagem 2 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 4, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 7.90 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Speaker Wire Repair: passo 5, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 5, imagem 2 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 5, imagem 3 %32
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Speaker Wire Repair: passo 6, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 6, imagem 2 %32
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Speaker Wire Repair: passo 7, imagem 1 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 7, imagem 2 %32 Kingston HyperX Cloud II Speaker Wire Repair: passo 7, imagem 3 %32
    • Remove the headphone speaker frame.
    • Solder the detached blue wire onto the driver.
    • Be cautious not to solder the wrong wire.
  8. Kingston HyperX Cloud II Speaker Wire Repair: passo 8, imagem 1 %32
    • Solder the green wire onto the driver.
Conclusão
Equipe
IUPUI, Team 1-4, Harley Spring 2023 Membro de IUPUI, Team 1-4, Harley Spring 2023
IUPUI-HARLEY-S23S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 26
Últimos 30 dias: 111
Duração total: 1,773
