Introdução
If your Kingston HyperX Cloud II headphone bracket becomes broken due to it having the plastic piece being stepped on, fully extended, or stuck in position, use this guide to repair or replace your bracket.
O que você precisa
Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
4 outras pessoas executaram este guia.
