Ir para o conteúdo principal
Kindle Touch Bezel Replacement
O que você precisa
  1. Kindle Touch Bezel Replacement, Back Cover: passo 1, imagem 1 %32 Kindle Touch Bezel Replacement, Back Cover: passo 1, imagem 2 %32 Kindle Touch Bezel Replacement, Back Cover: passo 1, imagem 3 %32
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch Bezel Replacement: passo 2, imagem 1 %32 Kindle Touch Bezel Replacement: passo 2, imagem 2 %32
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch Bezel Replacement, Bezel: passo 3, imagem 1 %32 Kindle Touch Bezel Replacement, Bezel: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  4. Kindle Touch Bezel Replacement: passo 4, imagem 1 %32 Kindle Touch Bezel Replacement: passo 4, imagem 2 %32 Kindle Touch Bezel Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
Conclusão
4 outras pessoas executaram este guia.
Jerome Narine
Membro desde: 01/20/15
221 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 19-5, Blackwell Winter 2015 Membro de USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
Membros da 3
Autoria de 8 guias
Um comentário
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 3,070
