Introdução
Use this guide to replace an old or faulty Amazon Kindle Touch battery. The battery may be due for replacement if your Kindle runs out of power quickly, won’t work unless plugged in, or won’t charge.
Make sure the device is powered off and disconnected from all external power sources before beginning this process. Please dispose of electronic waste responsibly.
O que você precisa
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
18 outras pessoas executaram este guia.
