Ir para o conteúdo principal
Kindle Paperwhite 3rd Generation Battery Replacement
O que você precisa
  1. Kindle Paperwhite 3rd Generation Battery Replacement, Battery: passo 1, imagem 1 %32 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: passo 1, imagem 2 %32 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: passo 1, imagem 3 %32
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: passo 2, imagem 1 %32 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: passo 2, imagem 2 %32 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: passo 2, imagem 3 %32
    • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
    • You want to make sure your separator goes through both sides of the bezel over top of the display.
    • The second photo is the layer you want your tool to pass through safely.
    • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
  3. Kindle Paperwhite 3rd Generation Battery Replacement: passo 3, imagem 1 %32 Kindle Paperwhite 3rd Generation Battery Replacement: passo 3, imagem 2 %32
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  4. Kindle Paperwhite 3rd Generation Battery Replacement: passo 4, imagem 1 %32
    • Gently lift the mid-frame out of the case with your hands.
    • Lift the side opposite of the power button out first.
  5. Kindle Paperwhite 3rd Generation Battery Replacement: passo 5, imagem 1 %32 Kindle Paperwhite 3rd Generation Battery Replacement: passo 5, imagem 2 %32
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  6. Kindle Paperwhite 3rd Generation Battery Replacement: passo 6, imagem 1 %32
    • Gently lift the battery from the frame.
Conclusão
76 outras pessoas executaram este guia.
Micah Smart
Membro desde: 02/10/16
3.108 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 14-3, Lacy Spring 2016 Membro de USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
Membros da 4
Autoria de 9 guias
19 comentários
Same for 5th Generation ??
PAUL FRIEND - Responder
where can i buy a new battery ?
david horn - Responder
you need a taobao.
lol
kassadin -
They are sold on aliexpress and ebay but the price of battery and postage is not that different from the price of a second hand 3ed Gen Kindle. But then the second hand Kindle will probably need a new battery too so, I am going to get a battery from ebay.
Timothy Takemoto -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 40
Últimos 7 dias: 303
Últimos 30 dias: 1,351
Duração total: 70,524
