Ir para o conteúdo principal
Kindle Paperwhite 2nd Generation Screen Replacement
O que você precisa
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: passo 1, imagem 1 %32
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, imagem 1 %32 Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, imagem 2 %32
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: passo 3, imagem 1 %32
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: passo 4, imagem 1 %32
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Conclusão
6 outras pessoas executaram este guia.
Tyler Davis
Membro desde: 09/15/16
1.697 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
Membros da 4
Autoria de 17 guias
3 comentários
My opening tool is orange. Will this still work for me?
FoxRunTime - Responder
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Responder
Did this work Liam?
Ben Lowdon -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 124
Duração total: 12,822
