Ir para o conteúdo principal
Kindle Paperwhite 2nd Generation Power Button Replacement
O que você precisa
  1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: passo 1, imagem 1 %32 Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: passo 1, imagem 2 %32
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Power Button Replacement: passo 2, imagem 1 %32 Kindle Paperwhite 2nd Generation Power Button Replacement: passo 2, imagem 2 %32
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Power Button Replacement: passo 3, imagem 1 %32
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Power Button Replacement: passo 4, imagem 1 %32 Kindle Paperwhite 2nd Generation Power Button Replacement: passo 4, imagem 2 %32
    • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
Conclusão
Tyler Davis
Membro desde: 09/15/16
1.697 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
Membros da 4
Autoria de 17 guias
5 comentários
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - Responder
Seconding this: where exactly can I purchase the button?
Oren Leifer - Responder
Same for me…..where can I buy this button?
Rob Hoenstok - Responder
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - Responder
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 56
Duração total: 4,697
