Ir para o conteúdo principal
Kindle Paperwhite 2nd Generation Motherboard Replacement
O que você precisa
  1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: passo 1, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 2, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 2, imagem 2 %32
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 3, imagem 1 %32
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 4, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 4, imagem 2 %32
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 5, imagem 1 %32
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 7, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 7, imagem 2 %32
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, imagem 1 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, imagem 2 %32 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, imagem 3 %32
    • Gently remove the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Tyler Davis
Membro desde: 09/15/16
1.697 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 47
Duração total: 3,638
