Pular para o conteúdo principal
Introdução
The case of your Kindle Paperwhite gets a lot of abuse from everyday life. Replace a cracked or a scratched case to restore that fresh out-of-the-box feeling.
Peças
Nenhum componente especificado.
  1. Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel. Do not insert the spudger too far under the bezel; it could easily damage the screen.
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
    I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
    NathanF - Responder
  2. Remove the eleven 3.0 mm Phillips screws surrounding the midframe. At the top of the display, a strip of black tape covers one screw. At the top of the display, a strip of black tape covers one screw.
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
    On 3G version you will not have the top middle screw.
    BJones - Responder
  3. Lift the midframe out of the case.
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
    There are clips in the bottom of the case helping hold the midframe in. Lift the top of the midframe up enough to clear the black back piece and then slide up and out.
    BJones - Responder
Conclusão
2 outras pessoas concluíram este guia.
Anthony Nahal
Membro desde: 25-01-2013
54 reputação
3 Guias de autoria
Equipe
Cal Poly, Team 3-33, Amido Winter 2013 Membro de Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Membros
10 Guias de autoria
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Responder
4 years too late but I found this
Pao-Tang Kao - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 24
Todo: 5,895
