Ir para o conteúdo principal
Kindle Fire HDX 7" Volume Button Replacement
O que você precisa
  1. Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: passo 1, imagem 1 %32 Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: passo 1, imagem 2 %32 Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: passo 1, imagem 3 %32
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Volume Button Replacement: passo 2, imagem 1 %32
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Volume Button Replacement, Rear Panel: passo 3, imagem 1 %32
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Volume Button Replacement: passo 4, imagem 1 %32 Kindle Fire HDX 7" Volume Button Replacement: passo 4, imagem 2 %32
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Volume Button Replacement: passo 5, imagem 1 %32
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Volume Button Replacement, Volume Button: passo 7, imagem 1 %32
    • Remove the two 2.1mm T5 Torx screws from the volume button retaining bracket.
  7. Kindle Fire HDX 7" Volume Button Replacement: passo 8, imagem 1 %32 Kindle Fire HDX 7" Volume Button Replacement: passo 8, imagem 2 %32
    • Pry up the volume button ribbon cable from the rear panel with the flat end of a spudger.
    • Pull up on the volume button ribbon cable to remove it from the tablet.
  8. Kindle Fire HDX 7" Volume Button Replacement: passo 9, imagem 1 %32
    • Remove the volume button from the rear panel.
Conclusão
Blake Klein
Membro desde: 01/29/17
72.162 Reputação
Autoria de 50 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 1,782
