Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Set the Kindle down on the rear case.
Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
Lift the retaining flap on the ZIF connector of the upper flex cable.
Gently pull the cable out of its socket.
Separate the display assembly from the rest of the device.
60 outras pessoas executaram este guia.
21 comentários
Where are the rest of the instructions???? I now have a disassembled Kindle and no idea how to install the new screen!
At the end of every iFixit guide, next to the "I did it! Success!" button, there is a message that says "To reassemble your kindle, follow these steps in reverse order." However in some cases, there will be a slightly different message. In the case of this guide, the message says "To reassemble your kindle, follow these steps in reverse order. Just make sure that you successfully connect the two flex cables to each half of your kindle and that you then align the two halves on the side opposite the camera before reassembling it."
while you are at it, try replacing the battery for a better experience.
I did, checkout this battery for kindle here :
