1. Remove the SIM card tray (if present in your model). Insert a large plastic opening tool next to the Kindle's headphone jack. Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Remove the SIM card tray (if present in your model).
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
      • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
  2. Set the Kindle down on the rear case.
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
  3. Lift the retaining flap on the ZIF connector of the upper flex cable. Gently pull the cable out of its socket. This  flex cable is delicate. Be careful not to crease or bend it while working.
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
      • This flex cable is delicate. Be careful not to crease or bend it while working.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Lift the retaining flap on the ZIF connector of the lower flex cable. Gently pull the flex cable from its socket.
    • Lift the retaining flap on the ZIF connector of the lower flex cable.
    • Gently pull the flex cable from its socket.
  6. Separate the display assembly from the rest of the device.
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
  7. Remove the following sixteen screws from the metal midframe on the rear of the device: One 3 mm Phillips screw from each corner
    • Remove the following sixteen screws from the metal midframe on the rear of the device:
      • One 3 mm Phillips screw from each corner
      • Four 3 mm Phillips screws surrounding the ports
      • Eight 3 mm Phillips screws from the body of the midframe
  8. Carefully remove the metal midframe. Carefully remove the metal midframe.
    • Carefully remove the metal midframe.
  9. Locate the charger and micro HDMI input located on the back side of your Kindle. Use your finger to gently apply pressure and push upward on the metal strip that faces the center of the Kindle. Be careful to not bend the black portion that connects the two inputs when removing the metal strip.
    • Locate the charger and micro HDMI input located on the back side of your Kindle.
    • Use your finger to gently apply pressure and push upward on the metal strip that faces the center of the Kindle.
    • Be careful to not bend the black portion that connects the two inputs when removing the metal strip.
    • Lift the metal strip on both sides by using your fingers.
  10. You have now successfully removed the charger and micro HDMI input.
    • You have now successfully removed the charger and micro HDMI input.
Conclusão
17 outras pessoas concluíram este guia.
Joel Wilcox
494 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-16, Forte Winter 2013 Membro de Cal Poly, Team 5-16, Forte Winter 2013
CPSU-FORTE-W13S5G16
5 Membros
7 Guides authored
Where can I purchase the Charger and Micro HDMI input replacement part for my Kindle Fire HD 8.9 tablet?
greggbaxter - Responder
If you search Google for "Amazon Kindle Fire HD 8.9" Dock Assembly" a few will show up.
Shawn Allen - Responder
ebay is going to have the most options for any phone tablet etc parts. Look for your model number (general tip) do not just look for as a example samsung s3 mini glass there are variants based on carrier. So make sure your buying a kindle fire 8.9 and not a hdx part. I think in the 8.9 hds there are 2 variants i know there are 2 storage configs. So make sure you get the right part.
First link on ebay search kindle fire hd 8.9 hdmi port (has both ports) http://www.ebay.com/itm/Kindle-fire-HD-8... 25 bucks (note i have not used this seller previously and do not in any way support him/her or say to not buy from him/her This is only a example link showing average cost) This likely is not the best deal it is 28 ship with the 3 shipping tacked on.
Nova Flare - Responder
I'm all finished, I had a real problem figuring out the lock key. Now that I am all finished though the touchscreen is unresponsive. What the heck could I have done? I found this quite simple. And what the heck can I do to fix it? Any help would be awesome. Thanks!
Aimee Gordon - Responder
Same issue here...
mikebrownson -
Visualizar Estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 51
Últimos 30 dias: 188
Todo: 20,959
