Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Remove the following sixteen screws from the metal midframe on the rear of the device:
Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
After taking off the metal casing, locate the camera.
Use your index finger to carefully lift up the silver clip located just under the camera until you notice the obvious click when it comes loose.
After you snap up the silver clip, move your finger to the opposite side so that you are now pointing into the Kindle. Finally push the camera outwards towards the edge of the device.
Once the camera piece is taken out, this is what you should end up with.
