Ir para o conteúdo principal
Kindle Fire HD 6 Speaker Replacement
O que você precisa
  1. Kindle Fire HD 6 Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Speaker Replacement: passo 2, imagem 1 %32 Kindle Fire HD 6 Speaker Replacement: passo 2, imagem 2 %32
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Kindle Fire HD 6 Speaker Replacement: passo 4, imagem 1 %32 Kindle Fire HD 6 Speaker Replacement: passo 4, imagem 2 %32
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Kindle Fire HD 6 Speaker Replacement: passo 5, imagem 1 %32 Kindle Fire HD 6 Speaker Replacement: passo 5, imagem 2 %32
    • Lift the speaker out of the device.
Conclusão
Cassandra Beck
Membro desde: 01/13/15
885 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 70-4, Forte Winter 2015 Membro de Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 722
