Introdução
This guide will show how to remove the battery from the Kindle Fire HD 6. You'll often need to remove the battery just to access and remove the motherboard. You might also need to remove the battery if it's damaged and needs to be replaced.
O que você precisa
Place the device face down on a clean cloth or another smooth surface.
Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
Maneuver the tool around the device until the back unclips from the front panel.
Gently pry the battery free from the adhesive holding it in place.
If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
18 outras pessoas executaram este guia.
2 comentários
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
