Ir para o conteúdo principal
Kindle Fire HD 6 Back Panel Replacement
O que você precisa
  1. Kindle Fire HD 6 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Back Panel Replacement: passo 2, imagem 1 %32 Kindle Fire HD 6 Back Panel Replacement: passo 2, imagem 2 %32
    • Carefully separate the back panel from the rest of the device internals.
Conclusão
000
Membro desde: 01/11/15
976 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 70-4, Forte Winter 2015 Membro de Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 44
Ao todo: 2,263
