Ir para o conteúdo principal
Kindle Fire HD 2012 Speakers Replacement
O que você precisa
  1. Kindle Fire HD 2012 Speakers  Replacement, Speakers: passo 1, imagem 1 %32
    • Using the plastic opening tool, carefully insert the opening tool on all four corners of the Kindle Fire and lift up until you hear a slight popping noise
  2. Kindle Fire HD 2012 Speakers  Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, start from one corner and go around the Kindle Fire using the tool in a down and up motion to continue to pop off the backing.
  3. Kindle Fire HD 2012 Speakers  Replacement: passo 3, imagem 1 %32
    • The Kindle Fire could possibly have tape on the inside, so take caution and look before attempting to remove the back.
    • After you lift all four corners and you check for tape, it is safe to proceed.
  4. Kindle Fire HD 2012 Speakers  Replacement: passo 4, imagem 1 %32
    • Once all the plastic clips holding the screen to the plastic back of the Kindle Fire are separated, the back should be safe to lift up completely.
  5. Kindle Fire HD 2012 Speakers  Replacement: passo 5, imagem 1 %32
    • Locate the 4 Phillips #00 screws and use the Phillips head screwdriver to unscrew them.
  6. Kindle Fire HD 2012 Speakers  Replacement: passo 6, imagem 1 %32
    • If your device has copper tape attached to the battery, carefully peel it off the battery.
  7. Kindle Fire HD 2012 Speakers  Replacement: passo 7, imagem 1 %32
    • Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
  8. Kindle Fire HD 2012 Speakers  Replacement: passo 8, imagem 1 %32
    • Lift and pull up the power connector cable that surrounds the battery
  9. Kindle Fire HD 2012 Speakers  Replacement: passo 9, imagem 1 %32
    • Locate the 1 T5 Torx screw and unscrew it.
  10. Kindle Fire HD 2012 Speakers  Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to remove the plastic piece that connects the wires to the motherboard
  11. Kindle Fire HD 2012 Speakers  Replacement: passo 11, imagem 1 %32
    • Lift the battery out of the device with your finger or the plastic opening tool.
  12. Kindle Fire HD 2012 Speakers  Replacement: passo 12, imagem 1 %32
    • Look at the speakers on the left and right side of your device. Unscrew the three 2 mm screws that hold the speakers down with the Phillips #000 screwdriver.
  13. Kindle Fire HD 2012 Speakers  Replacement: passo 13, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the black and white wires that are connected to the plastic black piece.
    • Use the tweezers to lift up the wires.
  14. Kindle Fire HD 2012 Speakers  Replacement: passo 14, imagem 1 %32 Kindle Fire HD 2012 Speakers  Replacement: passo 14, imagem 2 %32
    • Look at the motherboard and lift up the three copper flaps with your plastic opening tool
  15. Kindle Fire HD 2012 Speakers  Replacement: passo 15, imagem 1 %32
    • Locate the purple flap in the middle of the motherboard.
    • Lift up the little black flap to disconnect the purple flap.
  16. Kindle Fire HD 2012 Speakers  Replacement: passo 16, imagem 1 %32
    • Locate the red and black wire that is connected to the plastic black piece.
  17. Kindle Fire HD 2012 Speakers  Replacement: passo 17, imagem 1 %32 Kindle Fire HD 2012 Speakers  Replacement: passo 17, imagem 2 %32
    • Locate the five 3 mm screws and unscrew them with the Phillips #00 screwdriver.
    • Remember to unscrew the 3 mm screw underneath the cooper flap.
  18. Kindle Fire HD 2012 Speakers  Replacement: passo 18, imagem 1 %32 Kindle Fire HD 2012 Speakers  Replacement: passo 18, imagem 2 %32
    • In order to remove the black and red wire, you must first remove the motherboard.
    • Now it is safe to remove the left and right side speakers out.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,071
