Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Power off your Kindle before beginning disassembly. At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Peel the front panel off to remove it from the Kindle.
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Remove the ten 5.0 mm Phillip Head screws with the T5 Torx screwdriver. A magnetized screw mat can help you keep track of your screws.
    • Remove the ten 5.0 mm Phillip Head screws with the T5 Torx screwdriver.
    • A magnetized screw mat can help you keep track of your screws.
    You will break the newer vision of kindle just like this. there is a peg that connect the top center of the screen to the back case. Remove the black double sided tape in the center and push this peg back .
    Kyle Darnell - Responder
    If you see black double sided tape at the top of your Kindle, as the commenter above did, you are on the wrong model—have a look here to see if this is your model: Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
    Lipsmeyer - Responder
  4. Working evenly along the corners and edges, separate the internal contents from the back panel.
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
  5. Flip the screen over to face the motherboard and battery pack. Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
    • Flip the screen over to face the motherboard and battery pack.
    • Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
  6. Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector. Make sure to flip up the flap and not the connection itself. Pull the cable from the connector.
    • Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector.
    • Make sure to flip up the flap and not the connection itself.
    • Pull the cable from the connector.
    • No force is required to do this, as the name, ZIF, implies.
  7. Similar to the previous step, flip up the retaining flap on the white cable connector. Pull the white cable from the connection.
    • Similar to the previous step, flip up the retaining flap on the white cable connector.
    • Pull the white cable from the connection.
    • During reassembly, make sure the retaining flaps for both the white and copper colored cable connections are secured. As these are zero insertion force connections, the cables could potentially slide out if this is not done.
  8. Use the T5 Torx screwdriver to remove the eight 3.0 mm Phillips Head screws. Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
    • Use the T5 Torx screwdriver to remove the eight 3.0 mm Phillips Head screws.
    • Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
  9. Remove the motherboard.
    • Remove the motherboard.
Conclusão
3 outras pessoas concluíram este guia.
Michael Griffith
Membro desde: 02/02/2015
425 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-28, Amido Winter 2015 Membro de Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Membros
12 Guias de autoria
This doesn’t look like my 7th generation. Close but not quite the same. Does the motherboard have to be removed to replace the screen?
Shonna Partlow - Responder
Anyone know where to buy parts? I’m struggling to find any
Adrianne - Responder
yes this is Def not the same as my 7th gen but it's an 8 inch so maybe that's the difference.. all I see is 4 screws holding down the motherboard n I've removed them but still can't get the board loose.. it's like one side of it is held down under these plastic tabs that don't move..
Heather Hodge - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 65
Duração total: 4,515
