Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Once the gray plastic top piece is detached from the metal back cover, remove it.
Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
Remove the metal casing.
Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
Pry upward under the black tab with the spudger to dislodge the battery.
Use your fingers to lift the battery out of the device.
39 outras pessoas executaram este guia.
9 comentários
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
