Ir para o conteúdo principal
Kindle 1st Generation SD Card Reader Replacement
O que você precisa
  1. Kindle 1st Generation SD Card Reader Replacement, Battery: passo 1, imagem 1 %32
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation SD Card Reader Replacement: passo 2, imagem 1 %32 Kindle 1st Generation SD Card Reader Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation SD Card Reader Replacement, SD Card Reader: passo 3, imagem 1 %32
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation SD Card Reader Replacement: passo 4, imagem 1 %32 Kindle 1st Generation SD Card Reader Replacement: passo 4, imagem 2 %32
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation SD Card Reader Replacement: passo 5, imagem 1 %32 Kindle 1st Generation SD Card Reader Replacement: passo 5, imagem 2 %32
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation SD Card Reader Replacement: passo 6, imagem 1 %32
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
  7. Kindle 1st Generation SD Card Reader Replacement: passo 7, imagem 1 %32 Kindle 1st Generation SD Card Reader Replacement: passo 7, imagem 2 %32
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 1,975
