Ir para o conteúdo principal
Kindle 1st Generation Battery Replacement
O que você precisa
  1. Kindle 1st Generation Battery Replacement, Battery: passo 1, imagem 1 %32
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation Battery Replacement: passo 2, imagem 1 %32 Kindle 1st Generation Battery Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 102
Duração total: 16,694
