Ir para o conteúdo principal
Kihno Kit Album Battery Replacement
O que você precisa
  1. Kihno Kit Album Battery Replacement, Battery: passo 1, imagem 1 %32 Kihno Kit Album Battery Replacement, Battery: passo 1, imagem 2 %32
    • Insert a spudger into the gap and pull downwards, so the top lifts up.
  2. Kihno Kit Album Battery Replacement: passo 2, imagem 1 %32 Kihno Kit Album Battery Replacement: passo 2, imagem 2 %32
    • Pull out the wired component from the Kihno for better access.
    • Remove the old battery by pulling outward towards yourself, starting from the top.
  3. Kihno Kit Album Battery Replacement: passo 3, imagem 1 %32
    • Grab your new battery and place it where the old one was.
    • Angle the battery to where it is underneath the golden flap.
    • Push the rest of the battery down.
  4. Kihno Kit Album Battery Replacement: passo 4, imagem 1 %32
    • Place the wired components back into the Kihno.
    • Ensure the white button is sticking from the outside through its designated hole.
  5. Kihno Kit Album Battery Replacement: passo 5, imagem 1 %32
    • Using your fingers, push the top back into the Kihno.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 69
Duração total: 405
