Ir para o conteúdo principal
Kidzlane Walkie-Talkie Antenna Replacement
O que você precisa
  1. Kidzlane Walkie-Talkie Antenna Replacement, Antenna: passo 1, imagem 1 %32
    • Flip your device over so the back panel is facing up.
  2. Kidzlane Walkie-Talkie Antenna Replacement: passo 2, imagem 1 %32 Kidzlane Walkie-Talkie Antenna Replacement: passo 2, imagem 2 %32
    • Use the Phillips #00 Screwdriver to unscrew the four 4mm screws shown.
    • Take out the three batteries from the device.
  3. Kidzlane Walkie-Talkie Antenna Replacement: passo 3, imagem 1 %32 Kidzlane Walkie-Talkie Antenna Replacement: passo 3, imagem 2 %32
    • Gently separate the front and back panels of the device.
    • Gently remove the green circuit board and the black speaker from the plastic casing.
  4. Kidzlane Walkie-Talkie Antenna Replacement: passo 4, imagem 1 %32
    • Flip the green circuit board over, so that the end of the antenna is visible. Use the soldering iron to disconnect the antenna.
    • Carefully remove the antenna from the circuit board.
    • The antenna may be hot from the soldering device.
Conclusão
To reassemble your Kidzlane Walkie-Talkie, follow these instructions in reverse order.
Amin
Membro desde: 02/13/16
642 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team 1-1, Wilson Spring 2016 Membro de IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 968
