Ir para o conteúdo principal
Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement
O que você precisa
  1. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Batteries: passo 1, imagem 1 %32
    • Turn the controller over to the backside and locate the battery cover screw.
  2. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 2, imagem 1 %32
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 3, imagem 1 %32
    • Once the screw is removed lift the battery cover up from the controller.
  4. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 4, imagem 1 %32
    • Remove the 2 AA batteries.
  5. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Internal Chip: passo 5, imagem 1 %32
    • Remove both 6.0mm Phillips #1 screws holding the D-pads in place.
  6. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 6, imagem 1 %32
    • Insert wisdom here.
  7. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 7, imagem 1 %32
    • Remove the six 8.1 Phillips #1 screws.
  8. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 8, imagem 1 %32
    • Lift the antenna holder away from the controller towards the top of the antenna.
  9. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 9, imagem 1 %32
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  10. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 10, imagem 1 %32
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  11. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 11, imagem 1 %32
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
Conclusão
Rusbell Gonzalez
Membro desde: 09/17/14
219 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Hickman Fall 2014 Membro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 202
