Ir para o conteúdo principal
Kid Galaxy Morphibians Explorer Battery Replacement
O que você precisa
  1. Kid Galaxy Morphibians Explorer Battery Replacement, Battery: passo 1, imagem 1 %32
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Battery Replacement: passo 2, imagem 1 %32
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Battery Replacement: passo 3, imagem 1 %32
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Battery Replacement: passo 4, imagem 1 %32
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
Conclusão
Rusbell Gonzalez
Membro desde: 09/17/14
219 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Hickman Fall 2014 Membro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 2,561
