Ir para o conteúdo principal
Kid Galaxy Morphibians Explorer Axle Replacement
O que você precisa
  1. Kid Galaxy Morphibians Explorer Axle Replacement, Axle: passo 1, imagem 1 %32
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Kid Galaxy Morphibians Explorer Axle Replacement: passo 2, imagem 1 %32
    • Remove the wheels by pulling them away from the RC car.
  3. Kid Galaxy Morphibians Explorer Axle Replacement: passo 3, imagem 1 %32
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Kid Galaxy Morphibians Explorer Axle Replacement: passo 4, imagem 1 %32
    • Pry open the two gear covers on both sides.
  5. Kid Galaxy Morphibians Explorer Axle Replacement: passo 5, imagem 1 %32
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Kid Galaxy Morphibians Explorer Axle Replacement: passo 6, imagem 1 %32
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Conclusão
Rusbell Gonzalez
Membro desde: 09/17/14
219 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Hickman Fall 2014 Membro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 291
