Ir para o conteúdo principal
Keurig K55 Water Filter Replacement
O que você precisa
  1. Keurig K55 Water Filter Replacement, Charcoal water filter: passo 1, imagem 1 %32
    • Soak the new charcoal filter in water for 5 minutes.
  2. Keurig K55 Water Filter Replacement: passo 2, imagem 1 %32 Keurig K55 Water Filter Replacement: passo 2, imagem 2 %32 Keurig K55 Water Filter Replacement: passo 2, imagem 3 %32
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Keurig K55 Water Filter Replacement: passo 3, imagem 1 %32
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Keurig K55 Water Filter Replacement: passo 4, imagem 1 %32 Keurig K55 Water Filter Replacement: passo 4, imagem 2 %32
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  5. Keurig K55 Water Filter Replacement: passo 5, imagem 1 %32 Keurig K55 Water Filter Replacement: passo 5, imagem 2 %32
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  6. Keurig K55 Water Filter Replacement: passo 6, imagem 1 %32
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  7. Keurig K55 Water Filter Replacement: passo 7, imagem 1 %32 Keurig K55 Water Filter Replacement: passo 7, imagem 2 %32
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
Conclusão
Uma outra pessoa concluiu este guia.
Maria Kostourkova
Membro desde: 06/20/18
160 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 1,098
