Ir para o conteúdo principal
Keurig K40 Top Water Pump Replacement
O que você precisa
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: passo 1, imagem 1 %32
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: passo 2, imagem 1 %32
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: passo 3, imagem 1 %32 Keurig K40 Top Water Pump Replacement: passo 3, imagem 2 %32
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: passo 4, imagem 1 %32 Keurig K40 Top Water Pump Replacement: passo 4, imagem 2 %32
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro de USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
Membros da 3
Autoria de 5 guias
4 comentários
I NEED ONE OF THESE! Where can I find one????
G Steve - Responder
This is a check valve, not the water pump.
Rick Koen - Responder
Please rename this article. The item is not a water pump.
tvyse46 - Responder
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 49
Duração total: 9,400
