Ir para o conteúdo principal
Keurig K40 Open/Close Sensor Replacement
O que você precisa
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: passo 1, imagem 1 %32
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: passo 2, imagem 1 %32
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: passo 3, imagem 1 %32 Keurig K40 Open/Close Sensor Replacement: passo 3, imagem 2 %32
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: passo 4, imagem 1 %32 Keurig K40 Open/Close Sensor Replacement: passo 4, imagem 2 %32
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: passo 5, imagem 1 %32 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: passo 5, imagem 2 %32
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: passo 6, imagem 1 %32
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: passo 7, imagem 1 %32
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
Conclusão
Uma outra pessoa concluiu este guia.
jonathan
Membro desde: 02/08/16
738 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro de USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
Membros da 3
Autoria de 5 guias
Um comentário
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Duração total: 3,748
