Ir para o conteúdo principal
Keurig K40 Bottom Water Filter Replacement
O que você precisa
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: passo 1, imagem 1 %32 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: passo 1, imagem 2 %32
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: passo 2, imagem 1 %32 Keurig K40 Bottom Water Filter Replacement: passo 2, imagem 2 %32
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: passo 3, imagem 1 %32 Keurig K40 Bottom Water Filter Replacement: passo 3, imagem 2 %32
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: passo 4, imagem 1 %32
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
Conclusão
12 outras pessoas executaram este guia.
jonathan
Membro desde: 02/08/16
738 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro de USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
Membros da 3
Autoria de 5 guias
13 comentários
Where do you obtain a new filter?
Anthony Montoya - Responder
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - Responder
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - Responder
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - Responder
The answer seems to be: “You don’t.”
Van Davis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 121
Duração total: 34,420
