Ir para o conteúdo principal
Keurig K10 Mini Plus Cup Holder Replacement
O que você precisa
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, imagem 1 %32 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, imagem 2 %32 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, imagem 3 %32
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: passo 2, imagem 1 %32 Keurig K10 Mini Plus Cup Holder Replacement: passo 2, imagem 2 %32
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Conclusão
Mark Henein
Membro desde: 02/04/16
369 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-6, Blackwell Winter 2016 Membro de USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
Membros da 2
Autoria de 2 guias
Um comentário
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,464
