Ir para o conteúdo principal
Keurig K10 MINI PLUS Top Needle Replacement
O que você precisa
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: passo 1, imagem 1 %32 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: passo 1, imagem 2 %32 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: passo 1, imagem 3 %32
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: passo 2, imagem 1 %32 Keurig K10 MINI PLUS Top Needle Replacement: passo 2, imagem 2 %32
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: passo 3, imagem 1 %32 Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: passo 3, imagem 2 %32
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: passo 4, imagem 1 %32 Keurig K10 MINI PLUS Top Needle Replacement: passo 4, imagem 2 %32 Keurig K10 MINI PLUS Top Needle Replacement: passo 4, imagem 3 %32
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: passo 5, imagem 1 %32
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
Conclusão
Mark Henein
Membro desde: 02/04/16
369 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-6, Blackwell Winter 2016 Membro de USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
Membros da 2
Autoria de 2 guias
Um comentário
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 5,010
