Introdução
Replacing the Cold Water Reserve Arm is a fairly simple task that does not require a large time investment. Even beginners should be able to complete this replacement without the need for outside help.
O que você precisa
Lift the cold water reserve lid up to reveal its hinge.
Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Remove two 14 mm Phillips #2 screws.
Remove two 12 mm Phillips #2 screws.
Lift the arm off the assembly. This will reveal the tank hole as shown.
