Ir para o conteúdo principal
Keurig B70 Platinum Water Filter Replacement
O que você precisa
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: passo 1, imagem 1 %32 Keurig B70 Platinum Water Filter Replacement, Water Filter: passo 1, imagem 2 %32 Keurig B70 Platinum Water Filter Replacement, Water Filter: passo 1, imagem 3 %32
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: passo 2, imagem 1 %32 Keurig B70 Platinum Water Filter Replacement: passo 2, imagem 2 %32 Keurig B70 Platinum Water Filter Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: passo 3, imagem 1 %32 Keurig B70 Platinum Water Filter Replacement: passo 3, imagem 2 %32 Keurig B70 Platinum Water Filter Replacement: passo 3, imagem 3 %32
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
Conclusão
Emily Ramirez
Membro desde: 10/14/18
97 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G6, Rose Fall 2018 Membro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
Membros da 4
Autoria de 5 guias
4 comentários
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - Responder
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L -
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - Responder
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Dacaria L -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 99
Duração total: 10,514
