Ir para o conteúdo principal
Keurig B70 Platinum K-Cup Portion Pack Holder Replacement
O que você precisa
  1. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: passo 1, imagem 1 %32 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: passo 1, imagem 2 %32
    • Turn off and unplug the Keurig before starting.
    • Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
  2. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 2, imagem 1 %32
    • Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Depending on the angle, the guard can actually fall out instead. Be ready to catch it!
  3. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 3, imagem 1 %32 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 3, imagem 2 %32 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 3, imagem 3 %32
    • Push the black button at the bottom of the lid to remove the K-cup holder assembly.
    • From the top, lift the assembly out of the Keurig.
  4. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 4, imagem 1 %32 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: passo 4, imagem 2 %32
    • Grab the top and the bottom of the holder assembly and pull it apart.
    • Be careful when pulling the assembly. There is a sharp needle!
    • This step requires a little force.
Conclusão
Thu Hoang
Membro desde: 10/17/18
217 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G6, Rose Fall 2018 Membro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
Membros da 4
Autoria de 5 guias
Um comentário
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
slz2002 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 1,508
