Ir para o conteúdo principal
Keurig B70 Platinum Base Replacement
O que você precisa
  1. Keurig B70 Platinum Base Replacement, Base: passo 1, imagem 1 %32 Keurig B70 Platinum Base Replacement, Base: passo 1, imagem 2 %32
    • Turn off and unplug the Keurig before starting.
    • Turn the Keurig upside down so the metal base is exposed.
    • Remove the five 12.0 mm screws.
  2. Keurig B70 Platinum Base Replacement: passo 2, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 2, imagem 2 %32
    • Lift the metal plate off the Keurig and hang it over the side of the device.
    • Be careful! The metal plate is sharp!
    • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
  3. Keurig B70 Platinum Base Replacement: passo 3, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 3, imagem 2 %32 Keurig B70 Platinum Base Replacement: passo 3, imagem 3 %32
    • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
    • Pull out the red and white wires and put it off to the side of the Keurig.
  4. Keurig B70 Platinum Base Replacement: passo 4, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 4, imagem 2 %32 Keurig B70 Platinum Base Replacement: passo 4, imagem 3 %32
    • Pull out the water collector by gripping it tightly and lifting upwards.
  5. Keurig B70 Platinum Base Replacement: passo 5, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 5, imagem 2 %32 Keurig B70 Platinum Base Replacement: passo 5, imagem 3 %32
    • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
  6. Keurig B70 Platinum Base Replacement: passo 6, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 6, imagem 2 %32 Keurig B70 Platinum Base Replacement: passo 6, imagem 3 %32
    • Pull the power cord out from the plastic holder located near the water tank.
    • This step requires a bit of force so don't be afraid to pull harder!
  7. Keurig B70 Platinum Base Replacement: passo 7, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 7, imagem 2 %32
    • Remove the six 13.0 mm screws.
  8. Keurig B70 Platinum Base Replacement: passo 8, imagem 1 %32 Keurig B70 Platinum Base Replacement: passo 8, imagem 2 %32 Keurig B70 Platinum Base Replacement: passo 8, imagem 3 %32
    • Lift the metal base and hover it over the opening of the black plastic base.
    • Carefully raise the plastic base over the metal base until it is removed.
    • Make sure to pull the power cord through the base as well!
Conclusão
Steven Tran
Membro desde: 10/14/18
329 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G6, Rose Fall 2018 Membro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 565
