Introdução
In this guide, you will replace the LCD screen. This is necessary if the screen is faulty and does not display information properly.
O que você precisa
Open the K-Cup Chamber Housing Lid by lifting up the silver handle below the LCD screen.
Using the Phillips #1 screwdriver, remove the two 140mm screws connecting the silver handle to the top of the Keurig.
These may be #2 Phillips screws, so if a #1 bit doesn't feel right try a #2.
On the bottom of the panel, remove the white tab that connects the wires of the circuit board to the LCD screen
To remove the tab, squeeze in on the sides of it as you pull it out.
Remove the touch screen panel from your device.
Where can I purchase the replacement LCD screen?
5 outras pessoas executaram este guia.
4 comentários
Hello Alec,
Thank you for providing this repair guide! Could you kindly provide the screen size and where one might be able to purchase one? It would be greatly appreciated.
Regards.
Yes love the demo, now where would one find the screen to replace. Keurig states these are no longer available.
Try eBay. I saw one there.
I saw one on eBay.
