Ir para o conteúdo principal
Keurig 2.0-400 LCD Screen Replacement
O que você precisa
  1. Keurig 2.0-400 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Open the K-Cup Chamber Housing Lid by lifting up the silver handle below the LCD screen.
    • This is the part of the brewer you open to place a K-Cup inside.
  2. Keurig 2.0-400 LCD Screen Replacement: passo 2, imagem 1 %32 Keurig 2.0-400 LCD Screen Replacement: passo 2, imagem 2 %32
    • Place the Keurig on its side.
    • Remove the two 140mm screws located on the underside of the Chamber Lid using the Phillips #1 screwdriver.
    • Remove the top black housing that surrounds the screen.
  3. Keurig 2.0-400 LCD Screen Replacement: passo 3, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two 140mm screws connecting the silver handle to the top of the Keurig.
  4. Keurig 2.0-400 LCD Screen Replacement: passo 4, imagem 1 %32
    • Pull out the front silver handle from the top of the brewer.
    • This will further expose the LCD screen.
  5. Keurig 2.0-400 LCD Screen Replacement: passo 5, imagem 1 %32
    • Using the metal spudger, pry open the snaps holding the LCD screen panel to the brewer, just enough for the panel to pop loose.
    • Warning: These snaps are very delicate and can easily be broken. Practice caution as you perform this step.
  6. Keurig 2.0-400 LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the top black housing by lifting it up.
    • This will expose the frame of the Keurig connecting to the LCD screen.
  7. Keurig 2.0-400 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the black latch with the black wire connecting the front end of the panel to the frame.
    • The front end of the panel will now be free.
  8. Keurig 2.0-400 LCD Screen Replacement: passo 8, imagem 1 %32
    • On the bottom of the panel, remove the white tab that connects the wires of the circuit board to the LCD screen
    • To remove the tab, squeeze in on the sides of it as you pull it out.
    • Remove the touch screen panel from your device.
Conclusão
5 outras pessoas executaram este guia.
Alec Jamosmos
Membro desde: 04/22/18
936 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S24-G8, Maness Spring 2018 Membro de Cal Poly, Team S24-G8, Maness Spring 2018
CPSU-MANESS-S18S24G8
Membros da 4
Autoria de 5 guias
4 comentários
Hello Alec,
Thank you for providing this repair guide! Could you kindly provide the screen size and where one might be able to purchase one? It would be greatly appreciated.
Regards.
Christopher Rodriguez - Responder
Yes love the demo, now where would one find the screen to replace. Keurig states these are no longer available.
staci werkmeister - Responder
Try eBay. I saw one there.
DEBORAH A YOCHIM - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 104
Duração total: 15,914
