Introdução
In this guide, you will replace the circuit board. This is necessary if the board is faulty, which could make your brewer dispense drinks incorrectly. You will need to know how to solder and desolder connections to completely remove the circuit board from the device.
O que você precisa
Use the Phillips #1 screwdriver to remove the 120mm screw located on the top left corner from the side of the brewer where the water reservoir was.
Use the Phillips #1 screwdriver to remove another 120mm screw located under the end of the empty slot running across the left side of the Keurig.
Remove the entire back exterior surrounding the Keurig by removing the latches connecting the back exterior to the silver frame on top. To do this, use the metal spudger to lift the latches up and out.
Why are steps 12 through 15 required? It doesn't seem like they are needed to perform the final step, as the sensor and connector on the opposite side are both accessible at this point.
Reorient the brewer as shown in the picture.
Locate the four 140mm screws holding the top frame of the Keurig in place. Remove these screws using the Phillips #1 screwdriver.
Two of the screws are on the inside of the frame close to the water heater.
The other two screws are located on the outside of the frame.
Remove the top of the framing that encases the circuit board.
Remove the wires that are connected to the top of the circuit board.
Pull out the multicolored wires by their bases.
The bundle with black wires and one red wire is connected to the very top of the circuit board. To remove these wires, squeeze in the white tabs as you pull them out.
Unplug the rest of the wires connecting to the circuit board by pulling them out by their bases.
Remove the circuit board from the device.
Good day. What is the value/details of the MOV1 (metal-oxide varistor)? Thanks in advance.
Also want to know this capacitor part number. My one burnt out…
Excellent photos, especially of circuit board. Thanks! I am curious what manner of beast U1 is: FPGA, micro controller and/or any details. It’s been while since I worked on such control circuits and rarely mass-produced items so choices are different. BTW I cam here trying to troubleshoot why the clock is randomly reset, even in the absence of power failure. I can buy a cheap similar unit - not quite yet, at a thrift store if I wanted to replace the entire board.
The only things i know from the varistor : It’s from littelfuse and what’s printed on the varistor is LF9 P1505 1638 (on my K550 with a K543 MAIN BOARD) but no clue for real part number.
I would love to get my hands on a circuit diagram for this board. What do VR1 and VR2 do? Is one of them a control for the sensitivity of the pressure switch FPN-15PG that shuts the system down if the pump pressure gets too high indicating a possible clogged dispenser pin? The VR would go between pins 1 and 6 and be about 200 ohms max.
6 outras pessoas executaram este guia.
5 comentários
Just curious what the phone jack on the bottom is for. There seems to be no mention of this in the user manual.
Weird too that there is a UART mark on the circuit board. Is the coffee maker supposed to ‘phone home’ or obtain firmware updates? I think not.
is there a thermal fuse somewhere?
or if it’s dead, the circuit board?
I'm embarrassed to admit, I forgot which wire goes on which spade connector. :( I know for sure the red wire goes on the middle circuit board spade connector, but now I can't remember if the white wire goes on the top spade connector, or on the bottom corner. Does anyone have a photo of theirs or do you have a clear recollection of whether white is on the top or bottom spade?
