Ir para o conteúdo principal
Kenwood KMM-BT522HD Button Replacement
O que você precisa
  1. Kenwood KMM-BT522HD Button Replacement, Face Plate: passo 1, imagem 1 %32
    • Press the ejection button on the lower left corner of the face plate.
  2. Kenwood KMM-BT522HD Button Replacement: passo 2, imagem 1 %32 Kenwood KMM-BT522HD Button Replacement: passo 2, imagem 2 %32
    • Remove the face plate by pulling upwards and in the direction of the ejection button.
  3. Kenwood KMM-BT522HD Button Replacement, LCD Screen: passo 3, imagem 1 %32
    • Remove the three 7.5mm Phillips #1 screws.
  4. Kenwood KMM-BT522HD Button Replacement: passo 4, imagem 1 %32 Kenwood KMM-BT522HD Button Replacement: passo 4, imagem 2 %32
    • Separate the two halves of the housing by prying along the length of the device with a plastic opening tool.
  5. Kenwood KMM-BT522HD Button Replacement: passo 5, imagem 1 %32
    • Remove the motherboard from the housing.
  6. Kenwood KMM-BT522HD Button Replacement, Buttons: passo 6, imagem 1 %32 Kenwood KMM-BT522HD Button Replacement, Buttons: passo 6, imagem 2 %32
    • Remove the 5.5 mm Phillips #00 screw.
    • Remove the clear plastic piece by carefully prying it away from the plastic housing.
  7. Kenwood KMM-BT522HD Button Replacement: passo 7, imagem 1 %32 Kenwood KMM-BT522HD Button Replacement: passo 7, imagem 2 %32
    • Remove the gray rubber piece by pulling it upwards and away from the plastic housing.
    • Use the pointed end of a spudger to pry out the buttons.
Conclusão
Andrew Waldon
Membro desde: 07/05/18
265 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G4, Harley Summer 2018 Membro de IUPUI, Team S2-G4, Harley Summer 2018
IUPUI-HARLEY-SU18S2G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 234
