Introdução
If the volume knob in your Kenwood KDC-BT565U is not working properly or is loose/sticky, then it may need to be replaced. This guide shows you how.
O que você precisa
Grip the volume knob on the front of the device.
Pull the knob off. Some force may be required.
To reassemble your device, follow these instructions in reverse order. You will need to line up the shapes on the volume knob and the unit's axle to reattach.
3 outras pessoas executaram este guia.
