Ir para o conteúdo principal
Kenwood KDC-BT565U Fuse Replacement
O que você precisa
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: passo 1, imagem 1 %32
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: passo 2, imagem 1 %32 Kenwood KDC-BT565U Fuse Replacement: passo 2, imagem 2 %32
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
Conclusão
To reassemble, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Darren Evans
Membro desde: 02/15/17
273 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S2-G5, Lacy Spring 2017 Membro de USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
Membros da 4
Autoria de 11 guias
7 comentários
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Responder
it does not explain how to pull the reciever out.
d_lalande - Responder
same problem, how to remove the receiver
Jason Armondo - Responder
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Responder
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 52
Últimos 30 dias: 225
Duração total: 21,490
