Ir para o conteúdo principal
Kenwood KDC-BT362U DVD-Drive Replacement
O que você precisa
  1. Kenwood KDC-BT362U DVD-Drive Replacement, Front Panel: passo 1, imagem 1 %32
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U DVD-Drive Replacement: passo 2, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement: passo 2, imagem 2 %32
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U DVD-Drive Replacement: passo 3, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement: passo 3, imagem 2 %32
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U DVD-Drive Replacement: passo 4, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U DVD-Drive Replacement: passo 5, imagem 1 %32
    • Remove the front panel.
  6. Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: passo 6, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: passo 6, imagem 2 %32 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: passo 6, imagem 3 %32
    • Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
  7. Kenwood KDC-BT362U DVD-Drive Replacement: passo 7, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement: passo 7, imagem 2 %32 Kenwood KDC-BT362U DVD-Drive Replacement: passo 7, imagem 3 %32
    • Carefully separate the top and bottom halves of the metal case apart.
    • Do not separate the metal case halves completely.
    • Carefully pull the DVD-Drive ribbon cable from the motherboard.
  8. Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: passo 8, imagem 1 %32 Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: passo 8, imagem 2 %32
    • Use the Phillips #0 Screwdriver to remove the three screws.
  9. Kenwood KDC-BT362U DVD-Drive Replacement: passo 9, imagem 1 %32
    • Lift the DVD-Drive to separate it from the metal case.
Conclusão
Steven Chov
Membro desde: 10/04/16
349 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-5, Cagle Fall 2016 Membro de USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 496
