Ir para o conteúdo principal
Kenwood DRV-N520 Dashcam Motherboard Replacement
O que você precisa
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 3, imagem 1 %32 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, imagem 1 %32 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, imagem 2 %32 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, imagem 3 %32
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
Conclusão
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
1Comentário do guia
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 449
