Introdução
This guide will demonstrate the removal of the motherboard of the Kenwood DRV-N520 Dashcam.
This may be required if you are experiencing trouble powering on the device.
(it is recommended to check out our guides on the replacement of the fuse or capacitor as these are simpler problems that share the same symptoms)
O que você precisa
Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
Remove the back cover.
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
