Ir para o conteúdo principal
Kenwood DNX571HD LCD Touch Screen Replacement
O que você precisa
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: passo 1, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: passo 1, imagem 2 %32
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: passo 2, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 2, imagem 2 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 2, imagem 3 %32
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: passo 3, imagem 1 %32
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: passo 4, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 4, imagem 2 %32
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: passo 5, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 5, imagem 2 %32
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: passo 6, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 6, imagem 2 %32
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: passo 7, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 7, imagem 2 %32
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: passo 8, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 8, imagem 2 %32
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: passo 9, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: passo 10, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 10, imagem 2 %32
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: passo 11, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 11, imagem 2 %32
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: passo 12, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 12, imagem 2 %32
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: passo 13, imagem 1 %32
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: passo 14, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 14, imagem 2 %32
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: passo 15, imagem 1 %32 Kenwood DNX571HD LCD Touch Screen Replacement: passo 15, imagem 2 %32
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
Conclusão
4 outras pessoas executaram este guia.
Wendy Zaballos
Membro desde: 09/17/18
952 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 71
Duração total: 9,442
