Ir para o conteúdo principal
Kenwood DNX571HD CD/DVD Drive Replacement
O que você precisa
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 2 %32
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, imagem 1 %32 Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, imagem 2 %32 Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, imagem 3 %32
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: passo 3, imagem 1 %32
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, imagem 1 %32 Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, imagem 2 %32 Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, imagem 3 %32
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: passo 6, imagem 1 %32 Kenwood DNX571HD CD/DVD Drive Replacement: passo 6, imagem 2 %32
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Conclusão
Uma outra pessoa concluiu este guia.
Wendy Zaballos
Membro desde: 09/17/18
952 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 1,107
